I recently purchased an EB Voyager and noticed that the power cord plug catches the back of the cabinet if the panel is tilted back to its resting position. (I only noticed this after turning the synth off and using the dust cover). For those of you using a dust cover, do you unplug the power cord from the synth each time you cover it? I am mildly concerned that the plug bearing the full weight of the panel may damage the wood (or may incur damage).
But I am still in that “new parent” stage of owning this awesome synth, and am probably just overly-concerned
BTW: The Quiklok WS550 is a fantastic stand for the Voyager; it has my highest recommendation.
I extended the height of the rubber supports in the back by sticking additional rubber supports (may be found at local hardware store) on top of the existing ones.
My AE does if you leave the power cord in and try and tilt the panel all the way back into the case. Any 1/4" jacks plugged in will hit the case as well.
The rubber feet is a logical way to solve this.
