Last week-end, patching around, I noticed the square LFO output of theCP-251 did not trig the EHX 8StepProgram, while the LFO output on the VX-351 did. As per the CP manual, the LFO signal is going from -2.5V to +2.5V.
What about hte Voyager’s LFO output signal?.. Is it 0V to 5V?
But, you can put a bridge rectifier chip inside the end of a patch cable and make a rectifier cable or put a rectifier in a small experimenter case with a couple of 1/4" jacks. (Use a bigger box and make a rectifier, passive attenuator, mult box. Whatever you desire. Easy stuff with no circuit card and minimal easy soldering. Great beginner stuff that is functional.)
