I’ve recently replaced the battery on my Voyager EB.
Months ago on some patch names different signs appeared: / ? ) & ecc…
I saved my last patch. A month ago, after a month of not using it, at power up, the patch name was unreadable, just signs. Only PANEL light and no sound. I suspected battery problems and on the Forum I found something similar.
Hard Reset (-1 and +1) nothing. Boot System (ENTER and CURSOR) only if MASTER when light passes over MASTER.
Incredible. The MASTER, EDIT and PANEL menus were limited. By clicking ENTER, just a small line on the left.
I measured the battery: 2,87 VOLT. Kept on the first night: 2,89. And then: 2,95.
At power up asks for bank “C”, but the rest of the procedure didn’t work. Other measurements (Without opening it):
2,92 - 2,96 - 2,81. I ordered Battery vl-3032/gufn Panasonic. The new battery approx 3,2 VOLT. I replaced the Battery.
At power up asks for bank “C”, but this time everything worked.
I would like to thank Rudi.
