Voyager tuning
So I’ve just realised my Voyager has some tuning issues, sharper higher up and flatter the lower I go.
Is this something that happens and can be fixed myself or is this a job that requires sending it away to a professional?
I read some other threads but wasn’t 100% sure on what it was…
So further reading up on it, it is indeed a send away job. :frowning:
If it’s still covered by warranty, yes. If not (over one year since purchased new, or bought second hand), then no.
In the second case, with patience and good tuning equipment (precise tuner, or frequency meter) you can do it yourself.
The tuning procedure can be found on the Net.
Ive found that every now and then I have to re-tune my electric blue.
The weird thing is I tune all 3 osc’s to be the same at the 0 setting but after a few days (without moving the Voyager) I need to tune osc’s 2&3 to -2 in order to match with osc 1.
My guess is that osc1 goes slightly out of tune or something inside makes it go -2.
I just love the sound of all 3 oscs tuned properly, its such a powerful sound!
Good luck!
The reason for this frequent detuning is, by Moog Music’s own admission, the use of single turn trimpots for the scaling adjustment which are, as Amos has once said himself : “ridiculously sensitive…”
You may not have to send it away. Do a google search for synthesizer repair in your area. synthmuseum.com also has a reliable resource for finding synth techs near you. Support people who do this kind of stuff, it’s a dying art.
…unless it is still under warranty. In which case, better let Moog Music take care of you at their own expense.
It’s out of warranty, so I’ll do it myself.
It definitely can take a few additional nudges later to get it sitting just right. Also, in case anyone isn’t aware - when tuning osc 3 you need to detune Osc 2 fully using the front panel freq & octave knobs as osc 3 gets pulled towards osc 2 when they’re close.
@msjlra
Did you find the tuning procedure for Voyager ? If not, I can tell you where you can get it…
No I haven’t really been looking, I emailed Moog for it the other day, waiting for a reply.
But it would be great if you could direct me to it :smiley:
You can find it here (half way down the page under a long post by Revstate)
http://www.gearslutz.com/board/electronic-music-instruments-electronic-music-production/355562-keeping-voyager-tune.html
Careful though, there’s no mention of the proper way to tune osc 3. Here’s the exerpt as it appears in the tuning guide:
"Note on Osc 3 tuning: Osc 3 has the tendency to sync with Osc 2. You may find it helpful to de-tune Osc 2 before tuning
Osc3. Go to “init parameters” and turn Osc 1 off. Then, turn the Osc 2 Freq knob fully counterclockwise and turn the Osc
2 Octave switch down to 32.’
Thanks, but is there an official guide?
You’re welcome.
Since that was written by Amos Gaynes himself (of Moog Music Inc), I believe we can rely on it.
BTW, if you ever receive a reply from Moog, and get the “official guide” from them, you will be able to compare what they send you to what Amos had written…
Does anyone have a tuner plug in that they could recommend for this? Preferable an AU or a stand alone, would rather not have to buy something physical for this.
Haven’t heard back from Moog yet.
