Not quite MiniMoog but nearly.
It’s about a MIDI DAC VCA module based faithfully on the Minimoog circuits.
This is a module by AJH synths and I have two however one has started to leak an audio signal even with all controls set to off.
AJH told me it’s probably one of the Trim pots breaking down . There are two 100ohm ones as per the Mini vca circuit., however I’ve adjusted both these and it’s making no difference to the leaking audio.
I wonder if anyone has any info regarding this issue ?
