Using the filter in self-oscillating mode reveals differences between voices
The one is an analog synth, so, it is normal that each voice behave slightly differently. This is what makes the sounds of analog synth lively and interesting.
However, I found that when it comes to filter self-oscillation (turning the filter into a sine tone generator) - the different voices produce different pitches. The manual mentions using the filter in self-oscillation mode, to play is as an oscillator, and avises a filter keyboard tracking of 100% to do so. The problem is not the tracking, but the different voices that will self-oscillate to different frequencies. Which makes it unplayable, as a tuned oscillator.
To reproduce the issue, start from an INIT PATCH, crank the filter resonance to the maximum to make the filter self-oscillate, and then hit one single note, consecutively. You will hear a “pitch” sequence that has a length of 8 or 16 depending on your model. Like a ta-ta-ta-to-to-ta-ti-ti-ta-ta-ta-to-to-ta-ti-ti-…
Can we calibrate the filters manually?
Got in touch with support regarding this issue. Will be addressed in a future update. Nice!
Tested…same here
Hello hello, reviving this thread to see what others experience? My oscillators seem to be tracking fine, I haven’t ran a full calibration because I haven’t needed to. Initialising the patch, removing the oscillators from the mixer and setting the ladder filter to self oscillation with key tracking enabled reproduces this issue. Setting it to mono clears the issue so this means that small variations across the voice cards, affect the filter… should I run a full calibration or is there another workaround?
same problem here. One workaround is activating the mono mode when for example you need to design a kick drum. But if I want to use it in poly mode, each voice has a different pitch
