EDIT
1st I dont think my LP has ever made me as excited as I am today…
I think I’m writing my best noise yet…
BUT
Just after I recorded this one melody line using this one tasty thing that uses S-H and hooked up to Logics’ midi Clock using USB the LP decided to… Stay put a.k.a freeze.
So to see if things work I played the keyboard and there’s no audio coming out. I turn the knobs and every one of them seem to work and with their respective LED things. Tried Master Mode and when I’m there I can scroll to the right hand side but then it Keyboard Priority then freezes. I can go back to Preset Mode but the Preset look funny like… “07TARUSBASS” and so on… and still no sound. even when I turn the synth Off then On again…
PLEASE HELP SOMEONE…
Cradle___
…and in other news…
I think I’m having the best Moogasm yet… wow… I think every noise lover deserves to experience this at least once in their lifewhile… pass me a towel…
Take the USB cable from the LP…and see if it will work again…?
Make sure you have the output button under the volume knob turned on.
… those are the 1st two things I tried after it happened… still the same…
It’s anybody’s guess, but your next options are ( which you probable have thought of already)
1- The all notes off setting
2- System Utilities : restore factory settings
3- Reload OS through midi.
Sometimes, the obvious need being stated again. Good luck
make sure the arp isn’t on and waiting for an external clock source …
maybe we should have a sticky “things that keep the LP from making noise when you might otherwise expect it it to” thread …
Thanks aplenty for the input.
Thing is that it would get stuck on Keyboard Priority and go bonkers until I restart so I couldn’t do System Restore, but Amos hooked me up with that “CURSOR, ENTER, and OCTAVE” killer combination and everything was all sorted… after I re installed the firmware and reloaded my patches of course…
