Unison In Init Patch
Hi All,
Maybe this has always been happening and I never noticed… but when I load the init patch, it seems that there is some sort of unison mode with 4 voices going on. That is, when I press a single key, I can see 4 voices are used even though I don’t have unison mode on. If I set mono mode on then only one voice is used. Is there a setting somewhere that I don’t know about?
Disconnect all USB and MIDi cables and try again? Is it better? If yes, you got some MIDI loop.
You nailed it - thank you!
If you use the original setup, set the Moog One to LOCAL OFF mode. It should work this way with DAWs
