A couple of weeks ago, I installed the OS 3.1 in my Voyager Anniversary, and also manually retuned it by following the guide that came with OS 2.1. This seemed to help. Later, I transferred my favorite patches from my Mac to the Voyager by using the Moog Voyager Editor (1.5). Since then, most patches are again out of tune, and that makes it impossible to use the instrument seriously.
When the patches are without pot mappings you have to initialize these functions (MASTER/Copyright Info/ENTER/+1/Pot Mapping/ENTER/CURSOR to YES/ENTER).
Have fun,
Rudi
My Voyager AE has had a tuning problem since I installed the hardware upgrade. All of my presets require the fine tune know to sit at the 11:00 position to play at concert pitch. At the 12:00 position it is about a semitone off!
I’ve adjusted the digital board’s pot to get the 3.2V below and 4.8V above the initial value (a 31mV offset).
I’ve done the pitch wheel calibration procedure (it was at +1).
I did the software factory preset reset and I reset the pot mappings (RL suggestions).
Could there be a big issue here? I can live with the fine tune knob in the 11:00 position but I know that this isn’t the way it should be.
When I first installed it the fine tune was closer to 9.30, after about 10 hrs of use it has settled at the 11 position like yours. It took awhile for me to adjust to this, not sure why as my Source and Mini D are nowhere near the noon position either. I luv this new bd and the upgraded O/S. Anyone know when 3.2 is being released and what the updates are?
