Tuning Parameter Missing After Firmware v1.4 Update
I left my Muse turned on for a couple hours in my home n a hot day where I did not have the air conditioner on, and the temp according to the Moog sensor was ~45 Celsius… I noticed the temp after the one sound that was in tune when practicing earlier, was now out of tune when I came back.
I did a quick tune function in “tune” button, and it did not help…
Then I tried to do an full 2 hour auto tune like I did before in previous firmware versions. Only the Quick Tune option was available - again this is a month or so after I upgraded to v 1.4. After doing some investigation on the Internet, the manual showed I was in the correct place, but the option was not there.
I also found out that before doing a full Auto scale, to turn off the unit and let cool down for a half hour or so. I let it cool down overnight… when i turned on the unit the next day, and did a quick tune, everything seemed to be OK.. with the air conditioning now on on my home.
The question is.. is AutoCal a parameter/function on v1.4, or was it taken away? and if yes, why?
And an ancillary question.. I may use this keyboard to play live.. should I have a fan hitting it through out the n ight to make sure it does not overheat and go out of tune and have it on stage just for looks?
Thanks,
Takis
It’s now hidden behind a button combination press. See the latest user manual for details.
Thanks.. I am glad this option exists still.. but, if you would give a little more info.. I downloaded the ‘recent’ manual from the Moog website, and it just states this..
TUNING/AUTOCAL proceedures are unlocked by holding the outer soft buttons while in the TUNING
menu - procedures misspelled in manual too
My question is - what is meant by ‘outer soft buttons’??? it is not clear to me.
Thanks…
“TUNING/AUTOCAL proceedures are unlocked by holding the outer soft buttons while in the TUNING
menu.”
There are 4 buttons just under the Programmer display, these are the soft buttons.
