tryng to use Pot Map
i’m trying to use Pot Map but it seems to work strange…
or i dont understand something…
i got this sound where i need the lfo working (filter + wawe)
but i got no the left hand free to open the modulation whell…
and it seems the lfo work only thru the modulation module (via mod-whell value )…
so i had used Pot Map to redirect the MODULATION Knob to the ModWhell
so the mod-whell is down, but the value is setting from the pot map..
…and it works…and i had saved it…
and it save also the pot-mapped edit position…
but..
..when i change preset i found the modulation value modified
with the value of the pot map of the previous preset…
so i have the modulation active on all the presets with
the mod-whell on “zero position”…
…until i move the mod whell, and if i do…
i lost the value of the pot map…
and if i come back to the preset where i had used the pot map
i got no the initial value for it…but the current mod-whell position
(it is too visible on the panel but do not affect the modulation)
..so…
it look like that…the pot mapping is saved on the preset…
(the panel configuration)
but the value i edit with it …is global…
and the edited value is not saved on the preset as intial value
but only for ligth position (the leds around the knob)…
is it so ???
or i’m doing something wrong ???
Bruno.
