I have a problem and would be very grateful if any body can please help..on so many records I have heard vocals that have passed thru some sort of filter sweepin’ via an analog synthesiser…my problem is I am tryin’ so hard to re-create them but it seems I am not getting any where AT ALL..
A very good example of what I am trying to say was used on Craig David’s ‘Whats Your Flavour’ and also N.E.R.D ‘Lap Dance’ where the the girl Pharell, Chad and Shay featured vcocals where just sweeping from RIGHT INTO THE START OF EACH CHORUS LINE…Can someone please help…I need assistance…
Some friends of mine to me to try using the my Moog Voygers’ signal input..but still no result..any person also told me to try using My Malstrom Synth on Reason 2.5…BUT STILL NO RESULT…
maybe you don’t need to put your vocals’ signal into a synthesizer to get what you want…
check out the korg kaoss-pad (no links to suggest you, sorry…). it is a multi-fx unit also used by radiohead for vocals fx…
good luck!
bye
lollo
Thank you very much for your opinion which I try appreciate..but I want you to please search for the records I am talking about and have a listen at the backgrounds..YES! U are right it has been used on somany records..and trying/phatom this trick…
Please Andrew get your hand on these record and have a listen to it to be sure…
On AutoTune 3.0, my worry how do I get this effect out of it when it basically meant for auto tuning vocals to the right pitches of the song…
thanks alot men! …I hope you get to reply…I really dont mind sending you a sample via e-mail if I can have your e-mail address..
