I connected the kork sq 1 to my minimoog voyager and after a bit of fiddling with the cables the sound disappeared. I turned it back on and the synthesizer sounds went completely changed for the worse . Has this happened to anyone?
Which cable did you plug in exactly? CV? Gate?
The Korg SQ1 has an adjustable voltage range of 5v to 15v doesn’t it?
ho utilizzato entrambe le uscite
