Taurus malfunction HELP!!
Hi guys
I have a taurus III bass pedal.
Always worked flawlessly, however, it started producing some oscillation in almost all my patches.
I dont know if I pressed some wrong buttom or if its a malfunction.
Midi triggering is fine
What I have done already:
Replaced the power chord
Switched power outlets
Used different DIs
Tried Hi z and Low z outputs
Tried different cables
Did a master reboot
Return to original factory settings
Please take a look at the links below. I shooted 2 different effects with the problem.
http://youtu.be/w07DiD0umzk
http://youtu.be/NeB7vea_VbE
Please help!!!
Best
Marcos Freire
Anybody?? Any help would be appreciated…
Marcos
[/u]
sure you don’t have the resonance cracked up to max?
might be in the patch or that the velocity to resonance is set high.
did you already restore the os -software ?
sounds like the tuning, mate - have you tried a note calibration? if not, do that
Hi guys, many thanks for your insights.
I’ll work on it tonight and let you know.
Best
Hi, problem solved!!! Thank you Amos!
After calibrating notes, everything got back to normal, except for the effect showed in the second video. In this case, I just had to adjust the B freq of the oscilator.
I was using my T3 to control Apple’s mainstage via MIDI. MS was working accidentally out of tune (470 hz). Is it possible that MS got my T3 out of tune?
Best
Marcos
+1 calibration
