odd issue with my Taurus 2. The pedals on the left and right work but the middle dont.
It’s consecutive, about 5 on the ends, and then in the middle, nothing, no sound or anything.
Before I open it up, was hoping someone could provide some guidance on what I should look for once it’s opened. Appreciate the help.
Now look at me guy, I’m a proudly owner of T2 since the early days, and I had been also suffering from this issue, and now see what you can do first,…
As the T2 is suffering from weak metals, through the years the middle bar is bending downwards and the outer sides don’t, so you can play it there properly and in the middle any more, so here my quickly advice :
Put a rubber foot in the middle underneath, and the middle bar will be bend back soon while playing, if not, you cannot avoid open it up and bend the middle bar while standig upon with your full wheght, and then the middle bar will be back in right position, and you can close…
But NEVER PUT SOME COINS OR ST. LIKE THAT UNDER THE OUTER BARS AS THE PROBLEM WILL THE WORSENING !!!
Good luck,…
Christian
