Hi
Just received a set of Taurus 2’s from across the pond from a reputable dealer.
Guaranteed to be working 100%…(!)
The pedals were well packed and no signs of any damage to synth, pedals or packaging.
As this is a US sourced T2, the supplied PSU is 120V - but no problem, I used a converter to 230V.
On plugging everything together, I noticed the power LED flickered then went off and a a buzz was present in the monitor.
I replaced the 120V PSU with a UK 230V PSU - same problem.
I then removed the 5 pin cable between the synth and pedals and the power LED came on and the synth made synth noises!
I have checked the cable with a DVM and it is reading ok, all 5 wires intact and no short.
I replaced it anyway and the same problem occurs.
Seems the problem is in the pedal unit - any thoughts why is should be pulling the power down?
R
Alan
