I’m assuming there’s an obvious answer to this question, but I am stumped. When I go to Init preset patch to create a new sound the VCA envelope has no effect on the sound, the vcf envelope works as normal. If I use any of the patches on banks 1 through 9.6 the VCA EG works fine. Am I missing something here? Is there a setting to initiate the envelope? The Sub37 is only 5 days old. Any help would be appreciated.
Normally the VCA envelope should work with the INIT patch.
Do you have Knob Shift activated?
it is the button between the envelope generators.
When this button is blinking, The VCA and VCF envelope has different options.
hope this helps
thanks for the advice, I have given it a try and it hasn’t helped.
I think the problem is a bit bigger than I thought the envelope effect I had seen in the patches was most likely the EG positions as a modulation source, not effecting the signal path, so it looks like a faulty unit which I am taking back today.
