Sub37 use the step sequencer as mod
So I have gotten the sub to modulate lfo1 rate with the step seq. but it will only do it when having the step seq on, I would like to have one note latched and have the same effect. Is this possible?
Not if you’re using the step seq mod, you need the step sequencer on afaik. Why not just put the latch on the sequencer, same thing no?
Step sequencer was latched, but it seems to always be controlling the osc, is there a way to disengage the it from changing the osc pich?
Hi Jeffery&wayne,
From page 41:
SEQUENCER (PRESET EDIT 1.2)
SEQ MOD ONLY
When set to ON, this parameter prevents the sequencer from playing notes, but continues transmission of sequence mod values.
It effectively turns your sequencer into a 1-64 step modulation source. The default is OFF.
