Hello,
I have an issue with my Moog Sub37.
The Lfo 1 modulate the Lfo 2 rate without any mapping… any one have the same problem?
When I slightly push the lfo 2 button it goes back to his own rate until I hold off, then it get back to be controlled by the lfo 1.
I re-initialised the moog, checked all the mapping (with the control knob) for both lfo. I also opened the moog to see if there was any suspect thing or dust in the way, nothing…
Any help pls?
Is it the same behavior with different presets?
So I just got mine today and obviously I’m new to it, but it seems like on some patches LFO 1 won’t work and some others LFO2 won’t work. Even happened with an Initialized patch I made. Any else experience this? I’m assuming I’m just missing something obvious.
My first try would be to check the editor and see what is going on ‘inside’.
As the knobs don’t represent the current status when you change preset, it could be something obvious you are missing (like, LFO is not assigned to anything)
I never realized the second LFO was default mapped to aftertouch. Thank you for the heads up!
