Sub Phatty: Parameters controllable via MIDI (USB)?
sorry for starting a new thread but this should be way faster. :wink: So the sub phatty would be my first analog synthesizer and I would like to know if I can controll the parameters of the sub phatty with my DAW. For example modelling the frequency of OSC 2 with ableton so it gets a bit of a hovering sound. I would then connect the Sub phatty with USB and rout the audio out into my interface.
Thank you :slight_smile:
Yes, everything is controllable via MIDI. You also get the Sub Phatty Editor which you can load as a plugin on your tracks.
Cool. How far can you go with this? Can you animate something with a fast LFO or even with hearable frequencies?
You can download the Sub Phatty manual from the website. The default range is 0.1 - 100 Hz, but you choose from three LFO ranges as explained on page 28: 0.01-10 Hz, 0.1-100 Hz and 1-1000 Hz.
