Something weird is happening with my Sub Phatty updated to last firmware. Starting from scratch I can’t make a fast snapping attack sound. So I picked up a very fast attack preset from the librarian (HS_MiniDanceChor) and it sounds amazing fast BUT simply touching something on the panel (volume too) the snappiness disapperar ! The only way to have the snap attack back is to reload the preset using the preset button. I tried moving a little bit the cutoff and snappiness disappear (nosense), tried changing octave and back and snappiness disappear (nosense), touch whatever you want and snappiness disappear. This sounds like a bug to me.
Please let me know if I’m doing something wrong or if there is something to fix.
I checked again using the editor and midi-ox and the problem is that my EG AMOUNT pot moves (sending the midi cc too) the AMP ATTACK too (it’s like they’re chained togheter). All the other knobs seems to work both in stand alone and in the editor. Using the editor everything is fine, but using the Sub Phatty panel, the attack pot on the SP makes nothing but weird micro movement on the editor, while moving the EG AMOUNTpot on the SP makes both the virtual pot (EG AMOUNTand AMP ATTACK) move chained. I don’t know if it’s a hardware problem or firmware, I’m using 2.0.1. What shall I do ?
Yes, but I made all the possibile test.
The error occour with midi, with USB, with both and without any connection at all. It’s easy to catch it by ear, when you move the EG Amp the attach change to slow even if it was previously setted to zero.
I tried uploading the new firmware again (the firmware only, not the uploader). But nothing changed.
