I have Attack and Release at 0 and Decay and Sustain on Full to start testing
NOTE CALIBRATION, INITIALIZE GLOBAL PARAMETERS done just now.
Press any Key and get relatively loud clean noise (cleaner then Pink Noise Generator). If I turn up Release the Noise sustains but not as long as an OSC if I turn one up. If I turn OSC 1 to full and filter to 50hz the noise and OSC are about the same volume.
Also there is still sound from both OSC 1 and 2. Both follow Octave switching although only OSC 2 changes with Wave Select, OSC 1 stays the same with any wave setting.
There is an attack pop. This gets louder with OSC 1 Volume but not OSC 2, SUB or Noise> I need to turn Attack to just below 1 Second for the pop to stop (with any patch I have always had this issue)
I have the same issues on my sub phatty. I don’t think the first response gets the actual problem. I believe if both oscillators and sub and noise are on zero, we should not hear ANYTHING when keys are pressed, but what we are hearing is a bit of white noise. This is making it difficult to come up with clean bass patches. Does anyone know if this is on everyone’s sub phatty (I.e, a noise floor that can’t be removed) or if there may be some defect.
Do you get OSC sound with all at 0 also or just white noise?
Does the white noise respond to envelopes too? Perhaps as its a digital envelope we only hear the analog noise when the envelopes open? Still mine is way too loud to be acceptable for a modern synth, my SH101 is a lot less noisy!!!
First 4 seconds of the Video show the normal Noise floor without doing anything, after that you can see me press Keys a few times.
I couldn’t record Audio and Video together, but there are meters on ProQ and Ableton Spectrum that show the “Problem”.
I would like to know if this is normal for an analog Synth or if the Unit is faulty and I need to RMA it.
I’m going to go ahead and say I think this is probably normal operation. Mine behaves exactly as described in the original post. If you’re putting an oscillator in to a 50 cycles filter though, you’re basically filtering out the notes (except for truly subsonic stuff) then cranking a load of gain in to hear it despite it being filtered down, no?
Under what I’d consider to be challenging conditions, the SNR on my SP can drop to somewhere around 50 or 60dB (comparing signal with one oscillator on max, to envelope fully open noise). Obviously this ratio gets worse if you turn the oscillator level down. To my mind this is actually fairly reasonable for an analogue synth. Signal-to-envelope closed is more like 90dB+, and that’s probably down in to the noise floor of the sound card I’m measuring it with anyway…!
Regarding the clicking envelopes, I think that’s just how they are too. I guess it’s because when you start a note the oscillator doesn’t always start from a zero crossing like a sample would, it’s just doing whatever it’s doing, so unless you mask that by gliding the amp in & out, you’ll hear the snap.
This is normal. I had my unit serviced here locally for something else but while it was in I asked the tech about it. He let me listen to a Slim Phatty and it had the same ‘issue’ concerning the noise.
I found raising the multidrive up a little actually reduces the noise for some reason.
