Hey Moogys …
Wondering if one of you has succesfully synced their Sub 37 to An Elektron Analog Rytm? I am hoping to set the temp of the sequencer to the Rytm. I have already slaved my DSI Pro2 to the Rytm and it temp syncs as well as starts/stops in response to the Rytm. However going to the Sub37 … nada. I press sync button on Sub37 with the seq on/latch also pressed … start/stop the Rytm or change tempo … and nothing happens.
Wondering if I have missed a setting somewhere. Both devices on same midi channel. Can any one who has succesfully done this review their settings for me?
ok well after more messing around I was able to get the Sub 37 working in sync with the Rytm(tempo/start/stop). I was not able to quite use the output correctly using Sub37 thru port to the Pro 2 to continue the sync only. Nor was I able to sync the sub 37 using the thru port of the Pro 2. The Rytm does show it’s thru port as a “Sync B” but I haven’t been able to get that to work either. It might only work as a thru signal using master clock fed to the input. Maybe the only way is a device to split the Rytm midi out signal with a midi thru box. Fun with midi
I am running across a very similar situation, having trouble getting the Sub37 to pass along the MIDI Clock signal as a THRU. Really, I just want the Sub37 to echo the MIDI Clock and add nothing else to the chain. And, like the OP, have another piece of gear which also does not want to pass along the MIDI Clock.
Part of the problem is that, daisy-chaining MIDI (Clock, Notes, whatever) adds a finite amount of latency each time you run it thru something.
So… the best way to distribute MIDI Clock is via a MIDI Thru box. That way, every device is getting the same amount of latency (and less of it, as well).
Thanks Dan, that’s good to know. I’m also chaining synchronized devices, and I wondered if the sync could be better.
Would you happen to know if those thru boxes are able to be powered by the Sub 37 if it is used as the input…or if they will need the external power supply? (I noticed the Little Phatty is on the (long) list of products that don’t provide enough power).
Hi Demon_Dan … Can you confirm that the MIDI Solutions boxes are able to be powered by the Analog Rytm. Sounds like the perfect solution. Thanks! ps … great service from Sweetwater!
I did confirm from Elektron that the Rytm does not send midi clock via the thru port unless there is an input clock to pass. They seemed to suggest it would send a DIN24 or DIN48 clock instead of MIDI clock (not quite sure what that is) but I tried it and the Sub 37 didn’t respond to it either. So Demon Dan’s suggestion is probably a good solution for the price.
Only because my synth universe has no fixed home. I take my gear to live shows, I teach with it at schools and universities, I create stuff with it at Sweetwater, I jam at friends’ houses, and I occasionally write Owner’s Manuals on my dinning room table. So I tend to like solutions that can easily be repurposed to suit my current configuration.
But I have used many of the various MOTU interfaces when building other people’s rigs, and have always liked them.
Looked like a great solution, but it seems that the MIDI Solutions products cannot be powered by the MIDI output of the Sub 37 (according to Sweetwater).
Does anyone have a suggestion of another MIDI splitter that will work (one with integrated power options such as DC adapter or battery?) I know MIDI Solutions has a power adapter, but that means yet another box, and it’s only available by special order.
As I mentioned above I use a MOTU MIDI Express XT. It pretty much does is all. This is a great MIDI manager, I don’t know how I could live without it. Highly recommended.
8 input ports, 8 output ports
128 channels
Splitter
Merger
Routing (anything to anything)
Filter
SMPTE time code synchronizer
MIDI Machine Control
USB port for PC connection
Foot pedal jack
DC Powered
8 User definable preset configurations and 8 factory preset configurations.
Thanks! I saw that, but at first glance it looked like it was for use with a computer. But it seems you are saying it can be used without a computer as well, which might make it just the thing. I will take a closer look.
You only need the computer to setup the user defined configurations with the included editor After that it operates standalone. Power on and you’re good to go. You can of course also use USB for I/O to/from your DAW.
Just an update to my original post. I did end up purchasing a Midi Thru box with 4 outs (MIDI Solutions) from Sweetwater. I hooked up my Sub 37 and DSI Pro 2 both running their own sequencer. All worked as expected with the box being powered by the Rytm and the two synths being correctly synced to the Rytm’s clock.
