Hi All,
The 90+ Modulation Destinations on the Sub 37 open up entirely new areas of programming.
A few things that will help:
Remember that, if any of the MOD (1 or 2) CONTROLLERS have their values higher than 0%, you will never get your modulations to be full on unless those particular controllers are maxed.
If you’re sending to a destination that can also be modulated by something else (knob, switch, etc.) the two values will be added. This can be very useful; but it can also be confusing if you’re not aware of it.
Example: Lets say that you want to use a Square Wave LFO to modulate OSC 2 ON. You’d imagine that, as soon as you start sending the square wave to OSC 2 ON, the OSC 2 LED in the MIXER should start flashing. But… If you already have the OSC 2 ON LED lit, nothing will happen. That’s because the square wave is trying to push the ON button “farther than ON”. Instead, try setting the OSC 2 ON button to OFF. Now you’ll see it flashing. Alternatively, you could leave OSC 2 ON lit, but turn the MOD 2 AMT knob counterclockwise to send negative square wave to OSC 2 ON. With Square Waves it doesn’t really matter. But, if you try doing that with a LOOPing FILT EG, you’ll find that one polarity can be closer to what you wanted in terms of when OSC 2 is ON or OFF.
Adding a partial value to a MOD CONTROLLER that you aren’t using (especially CTRL4 AMT) is a useful way to make all three AMT knobs less powerful, and easier to fine tune.
CONSTANT ON as a MOD Source is the best way (currently) to get a CONTROLLER to directly modulate your chosen Destinations. After choosing CONSTANT ON as your MOD Source and choosing your Destinations, you can then add a percentage to MOD WHEEL, VELOCITY, AFTERTOUCH, or CTRL4 AMT. (To keep yourself sane, just use one CONTROLLER per MOD until you really get the feel of it.)
Don’t always set your MOD CONTROLLER to 100%. My methodology for setting modulation depths is to first set MOD WHEEL, VELOCITY, AFTERTOUCH, or CTRL4 AMT all at 0%. Now set all three MOD AMTs (PITCH, FILTER, MOD) to the maximum values (positive or negative) that you want to hear. Now (let’s assume you want to use MOD WHEEL) put the actual MOD WHEEL all the way down and start increasing the percentage until you hear the minimum amount of modulation you want to hear.
Again, don’t always default to 100%. Example: If you set up a vibrato with a TRI LFO to PITCH, you might find that a percentage less than 100% can give you just enough subtle motion to keep the oscillators sounding more alive and vibrant without actually sounding like vibrato.
- Try forcing the Sub 37 to act like two synthesizers. The trick is maximizing the use of all tools that let you do something to one OSC, but not the other: The OSC 1 + 2 buttons under GLIDE TIME, the OSC 1 + 2 buttons under PITCH AMT, the OSC 1 WAVE + OSC 2 WAVE DEST, KB CTRL LO + HI in DUO, SUB LEV, OSC 1 LEV, OSC 2 LEV, OSC 1 ON, SUB ON, OSC 2 ON, OSC 1 OCT, OSC 2 OCT, OSC 2 FREQ, and BEND DEST 1, and BEND DEST 2.
By using a Saw LFO (or Filter EG) to OSC 2 LEV, for example, you can create a separate VCA effect for that oscillator. Just remember that the longer-length OSC needs to use the regular AMP EG since both OSCs will run through it. (Nothing will sound longer than the AMP EG allows as it’s the last thing in the audio path.)
Be aware that MOD WHEEL, VELOCITY, AFTERTOUCH, and CTRL4 AMT are all multiplying against each other for your total modulation depth. Example: If you have a typical vibrato, and set MOD WHEEL to 100%, then there will be no vibrato if the MOD WHEEL is all the way down. (Makes sense, so far…) But, if you also set the AFTERTOUCH to 100% then you will get no vibrato if either the MOD WHEEL is all the way down AND/OR you’re not pressing Aftertouch at all. That’s because any value times zero is still going to be zero. (This is why I recommend using only one CONTROLLER per MOD until you really get it.)
Any time you’re trying to figure out a complex modulation, start by only assigning it to PITCH AMT. Our ears/brain are best suited for recognizing changes and patterns in pitch far more than timbre, amplitude, or other parameters. After you’ve figured out what it’s doing, then assign it to the actual destination you want.
Hope this is of some use…
