Hi Sub37ers
I been using my Sub37 in my live setup sync by Octatrack in a chain through Iconnect(the first one) over Mfb Dominion 1. It´s all working good and no probs there. No USB in this setup.
In the studio I´m got a new MBP and it´s limited on USB inputs so I want to hook up my MFB and the Sub37 over Midi din from the Iconnect to be able to sync/play and for the sub37 use as a controller.
MFB is hooked up In and Out with out issues, but I cant use the nobs as a controller(MFB does not support that)
But when I hook up the Sub37 the same way the Midi is not happy. The Midi knob on the Sub 37 is constant lid and it´receiving midi signal even though I´m not sending any. If I go into the MIDI setup menu I can´t change the channels nor In-Out put options.
If I hook the sub 37 into the USB of the Iconnect I can sync to a MIDI clip and play back from my DAW(Ableton) but if I press record on the MIDI track in Ableton I´m getting a midi conflict again and I can´t record anything or play back the midi clip that was working before I pressed the rec knob on the the Midi Track in Ableton.
When I´m having these issues the Midi Knob on the Sub 37 are 2 colors yellow and red, if that clears anything up!..?
My midi settings on Sub37 are:
In Ch:5
Out Ch:5
Send PGM:Off
Rcv:Off
In Ports: Both
Out Ports: Both
Echo Dim In: Both
Echo USB In: Both
Poly: Off
Poly Max:3
I´m using Ableton 9.2.2
MBP quad core 2,2, 16 gb ram flash 256.
Hope anyone has some idea of what I´m doing wrong, please share.
Thank
