Hello!
Is it normal that when i modulate the filter slopes it clicks at every pole changes?
If yes is there a way to get rid of that?
thanks! ![]()
Hello!
thanks! ![]()
Itโs normal and no way to get rid of it. If Iโm modulating poles as part of a patch I try to make sure the change comes on a new note so that the bump is less obvious. Hope that helps!
at least you confirm itโs normal
thanks a lot ![]()
