Square wave LFO not working
Hello everybody!
The square wave LFO of my Voyager Select is not working. I´m not able to use it in either of the Mod busses. S&H has also no effect (I assume it´s because of the missing square wave). The triangle LFO does work. I have also checked with the VX-351, same result. Does anyone else have this problem? Is there some global setting that I am not aware of?
Cheers
Dirk
Ok, I just realized that my Voyager is very likely in the group of units with faulty ICs, according to the support bulletin. I will check as soon as I´m at home.
