Hello beta group!
Sub Phatty Editor v2.0.0b13 is now available.
This version mainly fixes known High Sierra compatibility issues, as well as the following:
SPE-285 Align preset name to left on main field
SPE-284 Editor asks to sync each time it’s being launched
SPE-278 OSX .app name changed to “Sub Phatty Editor”
SPE-276 Remove “Cancel” button on sync page
SPE-248 Stuck notes when using Editor in Logic
SPE-270 Add V sign near the active preset on main list
Download:
(OSX) http://www.moogconnect.net/downloads/subphatty/Sub%20Phatty%20Editor%20Installer-2.0.0b13-OSX.zip
(Windows) http://www.moogconnect.net/downloads/subphatty/Moog%20Sub%20Phatty%20Editor-2.0.0b13-WINDOWS.zip
Firmware beta v2.1.12 (unchanged):
http://www.moogconnect.net/downloads/subphatty/Sub_Phatty_Firmware_Beta_v2.1.12.zip
IMPORTANT: Please check for the current SPH firmware version by loading the Editor and looking at the firmware version number on the PREF page. If it says 2.x, you may install this updated firmware. If 1.x, please check your unit’s serial number. If it’s #2892 or lower, DO NOT update your Sub Phatty firmware.
Windows Drivers:
v4.35.0 (Windows 7 and up): http://www.moogconnect.net/downloads/subphatty/Moog_Sub_Phatty_USB_Driver_v4.35.0.zip
v2.23.0 (Vista or XP): http://www.moogconnect.net/downloads/subphatty/Moog_Sub_Phatty_USB_DriverSetup_v2.23.0.zip
- Driver should be installed only once updating the firmware.
Updating the firmware:
- Connect your Sub Phatty to your computer using a USB cable. Connect it directly, and not using any USB hub.
- Turn the Sub Phatty on. Push HARD SYNC and PITCH AMT and while holding them both, push ACTIVE PANEL twice. If you push it only once, the update won’t work.
- LFO RATE indicator should blink slowly. This means that the Phatty is now ready to receive the new firmware.
- Load the C6 sysex program.
- Configure C6 midi ports so they point to Sub Phatty In/Out (“CONFIG”)
- Load the firmware syx file into C6 (“LOAD”)
- Mark the syx file by clicking it once, and then click “SEND”
- MIDI LED should now flash slowly. If it flashes very fast it means that the Phatty receives midi, but not updating the firmware. In this case turn the Phatty off and back on, and repeat the 3-button push scenario.
- Once the update completes, the Phatty should restart itself automatically. That means the new firmware is now updated.
- Run the Sub Phatty Editor and check for the firmware version by clicking on “PREF”. It should now say 2.1.12. If it says anything other than “2.1.12”, it means that the firmware is not successfully updated, and you need to repeat the process again.
Thanks for your cooperation!
