Hello moog beta group!
Following is a new Sub Phatty release-candidate firmware v2.1.9.
This version includes some few bug fixes, and should be tested for general functionality and stability. Please update your Sub Phatty, and use it as much as you can, reporting any issue on the forum. The version will be installed in the next production line of the Sub Phatty, so we have to make sure it works perfectly.
Additionally, we have created a new, dedicated Windows driver for the Sub Phatty. This new driver should allow DAWs use the Phatty’s Midi ports while used by the Editor plug-in, meaning that you should be able to send and receive Midi to and from the unit, while using the Editor.
NOTE: With the new dedicated driver for the Minitaur posted, there is no need anymore for the generic moog USB driver and it should be removed. Uninstall any existing generic moog USB driver from “Programs and Features” (Control Panel), and manually delete the files “moogusbmidi_x64.sys” and “moogusbmidiks_x64” under “Windows\system32\drivers” before continuing.
IMPORTANT:
Please check for your current firmware version, by loading the Editor and looking for the firmware version number in the preference page. If it’s 2.x, you may install the new firmware. If it’s 1.x, check for your unit’s serial number - if it’s #2892 and lower please do not update your firmware as it requires updating the bootloader. If higher, it’s safe to update to this new firmware.
Download:
Editor version is unchanged. For latest version, please see:
http://www.moogmusic.com/sites/default/files/Moog_Sub_Phatty_WIN.zip
http://www.moogmusic.com/sites/default/files/Moog_Sub_Phatty_MAC.zip
- OSX users should run the installer
Firmware v2.1.9, packed with the C6 sysex program:
http://www.moogconnect.net/downloads/subphatty/Sub_Phatty_Firmware_Beta_v2.1.9.zip
Sub Phatty Windows driver:
v3.30.0 (Windows 7 and up): http://www.moogconnect.net/downloads/subphatty/Moog_Sub_Phatty_USB_DriverSetup_v3.30.0.zip
v2.23.0 (Vista or XP): http://www.moogconnect.net/downloads/subphatty/Moog_Sub_Phatty_USB_DriverSetup_v2.23.0.zip
Please note the driver should only be installed after upgrading the firmware to 2.1.9, and not before.
Updating the firmware:
- Connect your Sub Phatty to your computer using a USB cable. Connect it directly, and not using any hub.
- Turn the Sub Phatty on. Push HARD SYNC and PITCH AMT and while holding them both, push ACTIVE PANEL twice. If you push it only once, the update won’t work.
- LFO RATE indicator should blink slowly. This means that the Phatty is now ready to receive the new firmware.
- Load the C6 sysex program.
- Configure C6 midi ports so they point to Sub Phatty In/Out (“CONFIG”)
- Load the firmware syx file into C6 (“LOAD”)
- Mark the syx file by clicking it once, and then click “SEND”
- MIDI LED should now flash slowly. If it flashes very fast it means that the Phatty receives midi, but not updating the firmware. In this case turn the Phatty off and back on, and repeat the 3-button push scenario.
- Once the update completes, the Phatty should restart itself automatically. That means the new firmware is now updated.
- Run the Sub Phatty Editor and check for the firmware version by clicking on “PREF”. It should now say 2.1.9. If it says anything other than “2.1.9”, that means the beta was not updated, and you need to repeat the process again.
Installing the driver (Windows only): - Power off your Sub Phatty and disconnect its USB cable
- In case you do not have any Minitaur in your system, uninstall any existing generic moog USB driver and manually delete the files moogusbmidi_x64.sys and moogusbmidiks_x64 from Windows\system32\drivers. Do NOT remove any existing Sub 37 drivers.
- Restart your computer
- Power on the Sub Phatty, connect the USB cable and let Windows auto-detect and install the default SPH driver. This may take a few minutes so be patient.
- Once detected, install the new Sub Phatty driver. The installer should load two popup windows, asking to confirm the driver components. Mark the checkboxes in those popups, and let it complete. If asked by the installer to disconnect and reconnect the cable, please do so.
- Check your Device Manager settings. There should be separate entries for the Sub Phatty, and also the Sub 37, in case one is present is your system. The entries should appear under the root tree, with no exclamation mark in them.
- Open the Editor, click the PREF button and select “moog Sub Phatty In/Out” from the Midi Input and Output menus. To sync all preset, click the GET button.
Testing:
As already noted, the main goal is to make sure that nothing is broken, compared to the version currently in production. Please try to extensively use your Sub Phatty, and test it across all features.
Thanks all for your cooperation!
