Sonic Six cinch jones question
Hi
Does anyone know if the 6-pin accessory port is used to accept a gate trigger?
Is there anywhere these cables can be found?
Accessory ports carry power supply rails only. No gate, trigger, or CV signals unless you modify the port’s unused pins.
Sonic Six accesory sockets are different from others. :slight_smile:
Here’s the pinout:
1 +15 volts out
2 Ground
3 -15 volts out
4 Pitch input
5 No connection
6 Trigger input
That’s what I get for never owning a Sonic Six
…and Polymoog accessory port has +5VDC on one of its pins, too.
