Some questions
I have updated my Voyager Os to 2.1 version.
Everything worked fine but I don’t understand why when I switch it on ,the sound that is displayed on the lcd appears with the “*” symbols like when a parameter has changed.It is normal???
Another question
How can achieve perfect tuning with the fine tune knob??
Bye
Sergio
The * * is there to let you know that you made a change in case you
    • want to save it.
…and does you heart have perfect pitch yet???
I know this but the sound appears with the ** when I switch the Voyager on without touching any knob
Wow…Yours must be broken.
Maybe try turning the voyager off on a non edited preset. The Voyager powers on with the same settings as it held before power down.
This must be the reason.
If you turn off voyager after you edited a sound and didn’t saved it, he will return to this sound after turn it on again. But i must agree, i had also sometimes , even when i was not touching any knob…? Midi-In Signals also change the sound, so check if there are some signals going thru.
