SOLVED: Panel does not work when local off
Now on latest release candiate the panel does not work when local is off (which it really needs to be when using DAW like Live)
When I turn knob on sub 37 the plug-in recieves it and turns the dial in the VST GUI and VST parameters but the sound does not change on the synth.
If I change the value in the plug-in it does change the sound.
See: https://dl.dropboxusercontent.com/u/5057386/Sub37%20beta/HW%20knob%20does%20not%20change%20sound.mov
Live 9.6 64-bit Mac OS 10.11.3
This was probably because the Sub 37 track was not armed even though I worked on the clip and used the plug-in. Then Live does not send MIDI back to the synth.
So for the Sub 37 panel to work with Local Off, you have to have the track armed. This also means you cannot play live on your Sub 37 connected to the DAW if the track is not armed. Another annoying thing by Ableton’s MIDI routing implementation.
Thanks for the heads-up.
