Slim Phatty: VCO 2 tuning pot is wrong
Hey, just got my first Moog, a gorgeous while Slim Phatty, but I’m finding a problem. First time I turned it on, left it warm up to be in tune and started playing presets: they all sounded wrong! I found out that if I turned VCO 2 slightly to the left the would sound right, as if the VCO 2 tuning pot was mis-calibrated. Now, I dug deep in the forum and found at you can actually calibrate pots on a Minitaur by running some sysex commands from a sequencer. Is there any way of doing this procedure on a Slim/Little Phatty? If not, is there an internal way of calibrating the knobs?
BTW calibrations have already been tried, one after the other in the order the manual states.
Ok, solved, it seems that a second round of calibrations did the trick and now it’s offset properly. I leave this in case it happens to others. Happy Slimphatty camper :slight_smile:
