How are the offending parameters behaving exactly?
Do all of the other parameters work as expected?
In the System Utilities Menu, there are various factory reset options which may be worth a shot.
I believe you have the latest firmware, so that’s probably not the problem (although if some other fixes don’t work, possibly re-loading the latest firmware again from your PC/Mac may help, in the future).
Good luck and I hope it gets working properly soon.
I use Ableton 9.0.4 , Windows 7 64 bit . During the video the Local Control is ON . I use USB midi ( I dont have DIN cables )
1:25 - I change the button to off and it makes the PASS THRU mode work fine but this way I cant record automations with the Slim , Also If I do the same thing on the OutPut ( The most bottom line you see in the video on 1:25) the PASS THRU mode works fine as well but this way I cant send MIDI notes to the Phatty .
I just do what I did in the video ( 1:25) so I can use PASS THRU mode properly . The problem is that when I do so , I cant record automations to ableton so I use the Slim as HW synth w/o any integration with ableton ( the only thing that I can do is send the notes to Slim , all other automations dont work well )
David - What DAW do you use ? I think it may be related to problems with ableton integration , as I also experience problems with recording and sending automation to/from the Slim .
I use Cubase - but I only use it to record the end result of what I do hands-on with the Moogs (I have no automation or anything set up).
It definitely seems as though it’s something to do with the Slim Phatty connection to Ableton - as it works fine otherwise. I’m afraid I can’t be of much help as I don’t use Ableton or automation etc. but perhaps contact Moog Support. Some other forum members may be able to help too, now that you have the video and more information up here.
I play my slim phatty as an external instrument in logic
and I just found out that
After I close the porject
The tracking problem just gone everything went alright
