I have a Minitaur and Slim Phatty. I have been testing the standard output volume of both synths via the default mono output and I noticed a significant discrepancy. In short I am measuring a -20db input into Ableton with the Slim Phatty versus a -6db input with the Minitaur. I have tested with both unbalanced and balanced cables, the result appears to be the same.
Can I assume that the SP is designed with a mono -10db line output while the Minitaur is designed for a +4 db line output (as my input volumes suggest), or is there another reason for this? Perhaps I missed this info in the manual. I have tested with both balanced and unbalanced cabling with the same result.
For the heck of it, I hooked up an insert cable (stereo TRS to dual mono TS) to the headphone jack to check volume levels on the SP and the default output level greatly exceeded 0db…not that this is meaningful, but it makes me wonder if my mono output on the SP is in operating as it should.
