Hi all,
I brought a slim phatty back in december and i seem to be having quite a few issues with it.
A loto f the time I will switch it on then leave it to warm up for around 20 minutes. However often when I go to play it it’s frozen so the lights are on but it won’t make any sound and when i press buttons on it it doesn’t do anything!
Switching it on and off resolves this. I also have the problem mentioned on this forum where the note hangs but not that often. I have also once had it completley freeze up with all the lights on and is then unresponsive and several times where the unit just stops outputing any sound.
These problems can usually be fixed pretty easily by switching on and off but it is frustrating and I was planning on using it live which with these problems just doesn’t seem viable. I was wondering whether anyone else has or has had the same issues and whether there is a resolution?
ps. I have tried restoring the phatty to factory defaults but am still experiencing the same issues!
Thanks in advance,
Mike
