I think a great addition to the MP-201 would be a simple lag processor. I was putting together a sound last night that used two discontinuous LFO signals. The end result was really cool, but it led to a lot of pops coming out of my speakers - probably not so good for them in the long run. I guess one option would be to get two CP-251’s, but that seems like overkill for something that might be pretty easy to do in the code for the MP-201.
Most of the LFO’s are discontinuous. Square, Ramp, Saw, and S+H all jump from one value to another at some point in the waveform. Square jumps between the two values, ramp jumps between the highest and lowest, saw jumps between the lowest and highest, S+H jumps between each random value. Those jumps can cause audible pops depending on what they are controlling.
A lag processor can be used to smooth out those jumps.
I fully understand the issue of the pops, and agree that a lag processor can be used to make a sudden change in CV value more gradual over time rather than a sudden pop causing change.
But what confused me was that I thought you were making an LFO discontinuous by adding a switch to turn the CV signal on and off at some rate, making a sound that could be described as (for example) a pitch changing Morse code. Just like thermionicjunky said, I thought you were making CV pulses. The rate of which was LFO controlled, while the second LFO controlled the pitch / effect.
LFO’s, or any wave / oscillation are in fact continuous, and this is what had me confused.
In a practical sense, maybe (though things do change quickly enough that I am getting pops). In an ideal sense, the square, saw, and ramp all have jump discontinuities.
For fun you should try out the CV Smooth function in the utilities menu (see p.40/41). This switches in a global filter (for all four CV outputs). It might help - it’s worth checking out.
I’ve tried it both ways and still get pops. The CV Smooth seems to have the most effect when LFO frequencies are in the audio range. It gets rid of ringing.
