Hi, even though I have set all local controll to OFF I still have issues when using the Sub 37 keyboard as my masterkeyboard in Logic. For example, if I have dialed in an arpeggiated preset in the Sub 37 and open a software instrument, whatever sound I play in that plug in will also be arpeggiated. Also, the octave of the preset in the Sub effects the octave of the software instrument preset and finally if I twist knobs on the Sub 37 certain paramters in the software instrument are effected. Any help is much appreciated since I am stuck with these issues.
There is a setting for what midi gets sent out. I think it’s in the “Global Menu” under “Seq Options.” Then in the “Midi Menu” there is also “Out Filters.” Those two settings should be helpful.
Thanks for your reply. But that was not the issue. Sometimes you need to ask a question in a forum to come up with the answer yourself. Hehe.
I simply had to open the External Instrument and select the correct midi channel of the Sub, that was it. I did that in the track instrument info panel but that does not work.
