Init Preset
-Global Menu: KB Priority High
-Play and hold some key in the middle of the keyboard
-Play additional keys above the held key : rather randomly higher notes will sound or not
Same issue (but the other way around) for low note priority .
Issue also occurs while sending notes via Midi
Just for completeness, the rest of this post is taken from the second link:
I tested some older firmware with only the Sub 37, no editor.
1.1.0 is from the zip file from the web site, dated 2015-05-18.
1.1.13 is a fresh download of the old file, contents dated 2015-11-24.
1.1.25 is the latest version that I saved, dated 2016-02-29.
1.2.0 is from the latest Sub_37_Editor_v1_0_0.zip file, 2016-04-13.
KB Priority Settings Results
Global Preset 1.1.0 1.1.13 1.1.25 1.2.0
Low any Low x x x
High any High x x x
Last any Last Last Last Last
Per-Preset Low Low x x x
Per-Preset High High x x x
Per-Preset Last Last Last Last Last
The “x” means a goofy response, as explained in the previous post.
Old FW 1.1.0 works the way I expected it to; FW 1.1.13, 1.1.25 and 1.2.0 do not.
