After recently purchasing and enjoying the fat sounds on the Moog Minitaur I thought it was time to start processing some audio loops through the synth. And have run into numerous problems in the process.
More often than not there’s a lot of noise in the signal, and seems to be a very temperamental set up, sometimes I can hear the audio and sometimes not - without any difference in the way I’ve set things up. I was getting a lot of noise from the USB connection (on a Macbook Pro) so I’ve since disconnected that. I’m running an audio signal from my headphone out on my Apogee Duet which doubles up as a second output, into the Moog Minitaur and then back out again and into input 1 on the Duet. I’m using balanced jacks.
I’ve got a sustained midi note playing back on the GM channel, with the VCO’s on the Minitaur turned down, envelopes and filter fully open.
The most frustrating thing is the audio sounds awesome and warm when I run it through the Moog - bar for the noise which renders the audio unusable.
Anyone who’s got any advice here would be a massive help - I’m using logic pro X.
