Rucci CV Sequencer with Werkstatt?
How can I use the EG with a Rucci CV sequencer?
https://handmadeelectronicinstruments.com/product/4-step-cv-sequencer/
To use the EG with a Rucci CV sequencer, you will need to connect the following cables:
EG Output 1 to CV Input 1 on the Rucci CV sequencer
EG Output 2 to CV Input 2 on the Rucci CV sequencer
EG Gate Output to Gate Input on the Rucci CV sequencer
Once the cables are connected, you can start using the EG to modulate the parameters of your synthesizer. To do this, you will need to set the EG’s parameters, such as the attack, decay, sustain, and release.
Here is an example of how to use the EG to modulate the filter cutoff of a synthesizer:
Set the EG’s attack, decay, sustain, and release parameters to create the desired envelope shape.
Connect the EG Output 1 to the filter cutoff input of your synthesizer.
Connect the EG Gate Output to the gate input of your synthesizer.
Play a note on your synthesizer.
The filter cutoff will now be modulated by the EG, and you will be able to hear the envelope shape that you created.
You can also use the EG to modulate other parameters, such as the VCA level, the LFO frequency, or the oscillator pitch. To do this, simply connect the EG Output 1 or Output 2 to the desired parameter input.
The Rucci CV sequencer also has a sync input and two sync outputs. You can use these to sync the EG with other devices, such as a drum machine or another sequencer. To do this, connect the sync output of the other device to the sync input of the Rucci CV sequencer.
I hope this helps!
