RME features new presets
Was reading through the RME User Manual (no, I don’t own one - yet!). You can download it here:
http://moogmusic.com/manuals/rme_manual_1.pdf
The manual contains a list of the new RME presets. They were developed by Moog Music, Nigel Hopkins, Brain Kehew, and Will Alexander (Keith Emerson’s keyboard tech).
Will’s contributions include a preset called ‘From the Beginning’, which is presumably the solo sound used by Emo at the end of the song ‘From the Beginning’ (from Trilogy). I’ve tried unsuccessfully to program this sound on the Voyager many times. I’ve gotten close, but never nailed it. It’s one of those classic analog synth patches that has been a ‘holy grail’ sound for me. Supposedly, the original was programmed on a modular. Cool if Will’s patch is the same as the original.
Hopefully these sounds will get posted soon for all Voyager owners to enjoy!
Hello,
This version from my own soundbanks.
Osc 1: Wave-Tri, Oct- 2’
Osc 2: Wave-Tri/Saw (1.5), Oct- 16’, Freq-0
Osc 3: Wave-Tri, Oct- 8’, Freq-0
Mixer
Ext: On, Level: 5.8
Osc1: On, Level: 9.5
Osc2: On, Level: 2
Osc:3: Off
Filter
Freq: 1Khz
Spacing: 0
Resonance: 0
KB track: 0
Mode: Dual LP
Slope: 4-Pole
FEG Amount: +1
Filter EG
Attack-7mS, Decay-14mS, Sustain-9, Release-14mS
Amplitude EG
Attack-10mS, Decay-14mS Sustain-9, Release- 14mS
LFO
Rate: 5.5Hz
Sync: Off
Wheel Bus
Source: Tri, Dest: Pitch, Shape Filter Env, Amount: 2
Pedal Bus
Source: PGM (Filter Env)
Dest: PGM (Resonance)
Shaper: Filter envelope
Amount: 1.8 (fixed)
Miscellaneous
Glide: On
Release: On
Glide Rate: 3.9
Trigger: Single
Sync: Off
3>1 FM: Off
Bend range: Minor 3rd
Output config: Left output only (with or w/o dummy jack)
Filter feedback loop if more gain desired.
Regards,
LWG
LWG -
Save your patch and consider posting it online. You can’t post here, but you can post files over at the Yahoo Groups Voyager page:
http://launch.groups.yahoo.com/group/mmvoyager/
You must be a member, but joining is easy. Not much activity there unfortunately (it’s all here), but at least there is space to submit a patch.
