I noticed a couple of things about OSC 3 and wondered if these are “normal”?
When OSC 3’s tuning knob is at the centre “0” position, it is a major third above Osc 1 tuning, or Osc 2 at centre. At full clockwise it’s an octave higher, and and full counter clockwise its a fifth lower. Is this intended? It would seem to me it should be calibrated the same as Osc 2. It is convenient though as I can quickly dial in 5ths octaves at each end of the range.
The Osc Range for Osc 3 is an octave lower than the equivalent range on Osc 1 and 2 - this seems correct as the LO setting produces an appropriately slow waveform
Hi - took it back to the shop and picked up the other one that was there - obviously this is just a poorly calibrated one out of the factory.
Would have done the calibration myself, but there was a brand new replacement to take instead, so I went with that.
There seems to be a problem with the final inspection. The error with the multtrigger mode was not discovered at my instrument (and also at some others). I find this in this price class very unfortunate.
