question about the delay pedal
i just ordered the moog analog delay? 2 questions.
Can the voodoo lab power supply, power this pedal, or would that mess up the pedal.
will any brand of expression pedal work with the delay pedal?
I think the pedal power has special red plugs that reverse the polarity (MFs need +9VDC at the tip). If you don’t have these, you can make your own (radio shack).
Most brands of expression pedal should work with Moog pedals. It needs to have a 50/100kOhm pot in it, which you can check with a multimeter. Check the manual for more details, and to see if your pedal is wired correctly.
