I have a Voyager and just picked up a sub phatty. I have a question about the 2nd patch in bank #1. This patch has a repeating pattern like an arpeggio. Since the sub phatty does not have an arpeggio, can anyone tell me how that pattern was created?
How do you turn that repeat on and off? Also, that patch has movement so its not like a single note played over and over. Can you help me with how that is created?
Filter Envelope Repeat is a hidden parameter in Shift mode. Shift mode is documented starting on page 23 of the manual. You will have to enter Shift Mode first and then turn on Filter Envelope Repeat (page 30). Play around with the filter envelope generator and you will get a better idea of what’s going.
From the manual …
When filter envelope repeat is enabled, then the delay, attack, hold, decay, and release stages will loop continuously for as long as the note is held. The shorter the envelope times, the faster the loop will repeat.
