Hello there
Which power pedal is known to be able to power up the Minitaur?
I have got a couple and no cigar…
Kind Regards
Hello there
Kind Regards
minitaur requires 12v.
typically pedal power supplies are 9v.
moogerfooger pedal power supplies are 9v.
minitaur has positive on the inside of the jack.
typically pedal power supplies have positive on the outside of the jack.
moogerfooger power supplies have positive on the inside of the jack.
the minitaur power supply delivers 1200mA
a typical pedal power supply delivers 300mA.
plugging in a pedal power supply to the minitaur could damage the unit.
cheers
Hello here,
Thanks for reminding me that this might be a good thing to do ![]()
But I trying this forum hoping than one had tried something out…
The reason is that I har tried with other 12V stand alone power supply, delivering less that 1.3, and it worked.
Some pedals do deliver 12V, like the voodoo 4x4… so I thought maybe, by merging 2 of its 12V ouput (totalling .8A), it might work…
Cheers
or you could just buy a Hosa ACD-477 on ebay for 10 bucks
i’d wager that the power circuits are not independent and joining them would not result in increased mA capacity.
even if it did work, it’s not the 1200mA you need.
