OS 2.0 MIDI Problem
updating to 2.0 was fine, I followed the instructions very clearly and I can see every pot of the voyager sending it´s cc to the midiinterface, finally! :sunglasses:
BUT:
now when I record something in Logic 6.3 (midi) even without controller data, just plain note on´s from the voyager´s keyboard, there are only a few notes played back, and not everything I´ve played…same when I control it from an external midikeyboard.
there must be some setting wrong in the voyager because that worked good with Logic before..
and I also wonder how to change the Velocity Curve in Master Mode..there is “Hard” but I can´t change it to something else..
oki, I´ll re-read the readme and hope that somebody chime in with similar problems or even somebody from moogmusic helping me with my issue!
thx alot,
cheers, moritz
:slight_smile:
For the only a few notes played back problem: Under the Master menu select Midi Key Order and set it to none.
For the velocity curve problem I’m stumped. After hitting enter at the velocity curve menu are you using the arrow keys to scroll through the options? Works fine here, maybe you will have to reload the OS. :question:
Good luck,
Joe
ha, joe thx alot..Midi Key Order solces my problem! :sunglasses:
for the Vel.Curve:
I´m using the arrow keys but nothing happens..
but I can easily live with that!
cheers, mo :slight_smile:
