I really love it, I love the Moog sound, but when it comes with MIDI it seems never to work as it should…
Now, I transformed my attic keyboard rig in a small-but-slowly-growing-up project studio, so I bought all the things I need, including Ableton Live.
I connected the MIDI ports of the Phatty to the audio interface’s ones, and generally it works fine, but (omitting the sustained note problem) the Phatty plays only one of three notes.
Yes, if I (or Ableton) play three notes, only one of these will actually sound.
This is as interesting as annoying ![]()
I disconnected the MIDI cables… and… it’s still so!! ![]()
Because I live in Italy, I’m dying to send my synthesizer to the Moog factory, I hope there will be a solution…
Thank you so much, have a nice day everybody! ![]()
If it’s always 1 in 3 then it could be that the polyphonic option is activated and set to 3 voices.
The phatty uses a round robin policy in polyphonic mode, if I’m not mistaken.
Take a look in the global menu and set it to 1 voice.
I hope it helps.
Sorry if I am reading incorrectly but from what you are saying you are trying to play three notes at once? All of the Moog synthesizers are monophonic, can only play one note at a time. So it is performing as it should . Again, sorry if you knew that . If so, check the poly Assign Mode as suggested.
The poly-mode was the problem (shame on me
Now, I’ve got another question: my current OS is a beta-version (3.1 653/33) found on this forum while they were developing OS3, but it seems to have some bugs in it - LFO Sync doesn’t work with my computer, e.g.
I noticed that OS 3.12 works properly, but the updater that I downloaded from the site is set to take the OS 2.x to the 3.12.
Now, I have 3.1, so that updater doesn’t work… what should I do? Wait for the next OS update? ![]()
Well, from what I’m told (due to a problem I’m currently having) the will infact be an OS update started in the next few months. Mabey you should mention this to Amos?
Thank you! I’ll look for him ![]()
