NOTICE: Please install Sub 37 Editor v1.0.0 (RC1)
Following are the links to v1.0.0 release candidate:
http://www.moogconnect.net/downloads/sub37/Moog_Sub_37_Editor-1.0.0_RC1-WINDOWS.zip
http://www.moogconnect.net/downloads/sub37/Moog_Sub_37_Editor-1.0.0_RC1-OSX.zip
This may NOT be the final version yet. In any case we need to recompile these files, we will send a note and instruct to re-download the version again. Please DO NOT publish these files or provide direct links to them, as it may create a duplication of 1.0.0 versions across the net, and this version is still very confidential. The only reason it carries the name 1.0.0, is to make sure we do test what may become the final release, which should be the case if no blockers arise during this final test.
NOTE - This version should run with firmware v1.2.0 (which is beta v1.1.30).
Download from: http://www.moogconnect.net/downloads/sub37/1.2.0_pre-release.zip
However please note that OSX updater may not run, so OSX users need to send the syx files manually at this point.
We will post a final package soon, including the official, working 1.2.0 firmware updater and final documentation.
Thank you for your great job during this beta phase !
Installing now
Will give it a good test today, What has changed in this update?
MESA
The only change is reversing the change made to SAVE AS on 0.9.55, and a bug found when the Editor would send preset name changes to the synth although AUTO SEND was off, if you renamed from the top menu.
The RC is risen!
You guys rock.
Successfully installed the 1.2.0 FW and now using the 1.0 Editor standalone x64 version on Windows 7. So far, it seems to work. Still delving into the features.
Hi
Looks fine Guys.. Copy, paste, save as, is there again.
Tuning scale:
In editor it goos from 0 to 31.
But we have only 16 scales.
Regards Luloop
Latest OSX El Capitan 10.11.4 : flawless install , both updater and editor
Cheers
HansH
Thanks Luloop,
The Editor matches the firmware range which is set from 1 to 31 (although not all of them are in use).
Thanks !
Hi..
Saving a seq is working fine..But I have always to click 6 times with my mouse to move to this folder: (1)User(2)Username(3)Appdata(4)roaming(5)Moog Music(6)Seq to save a seq.
6 clicks with the mouse Every time.
Why not, when you save a preset!!!..Then you jump Automatic to this folder.
Regards Luloop.
We changed it all in the next RC. We will post it soon, thanks.
Gil,
When editor is released will you need to tell people to delete previous presets, or will that no longer be necessary?
Iain
Hello Iain,
You do not have to delete any presets anymore. You can keep them between the versions.
Thanks, Gil.
Working fine now in (RC3)
Cool
Regards LuLoop
