I’m only getting a response from my sub phatty if it’s being used via the AU in Logic. With that I get sound and I can edit it from the plugin but that’s as much as I get. None of the controls on the synth have any effect either on the guy of the plugin or the sound coming out of the synth. If I quit Logic I get nothing at all. Not even the keyboard works.
The activate panel button is lit up and the audio is definitely set up correctly as I get a signal if I plug the cable in somewhere else so I’m not sure what I’m doing wrong.
Is there some setting which completely disables the hardware?
Thanks for your reply. Yeah local off has got the synth working so thanks for that but it still doesn’t have any effect on the software. If I move a knob on the synth the software stays where it is.
I’ve tried restarting [computer and synth] but it doesn’t change it.
